Following route created on Basecamp
Posted: Wed Jun 12, 2019 2:53 pm
Hi
I am using a Zumo 346. I have created a route on Basecamp initially using Waypoints then converting them to Shaping Points and then downloading it onto the Sat Nav.
The route is not starting from home but from a point about 30 miles away where as a group we will be starting off from. On checking the Map route on the Sart Nav the map is as planned, though it has gained some 6 miles between the Basecamp route and downloading it onto the Sat Nav?
However, if I hit the Go function it asks the next destination, which I select as my chosen end destination and it then goes on the calculate the route. However, this now a totally different route to the one I created using the Waypoints (now Shaping Points).
So what I would like to know is this because I have asked it to calculate the route from my current home position and not the original start point and as a result it has just simply chosen the fastest route to the end destination?
I would have thought that it would take the fastest route from my present home location to the programed start point and then follow the route that I have created using the Shaping Points?
Can anybody advise as I am concerned at the moment that if I select and start the route from my actual programed start point it will do the same and not follow the planned route?
