Adding Addresses to 595
B52
Post by B52 »
I have run into a snag all of a sudden with trying to add and save address.
I no longer have the option to do this, the Zumo lets me find the address but then want to display the Route and never saves it.
Anyone have a suggestion?
Thanks
B52
Has liked: 344 times
Been liked: 369 times
Re: Adding Addresses to 595
When you do a where to, then select the location, don't you see a screen with an icon an i? Tap the i then the three bar icon top left. Or you may see a Save button.
Suspect you've been selecting Go instead
B52
Post by B52 »
Sussamb
Thanks for the tip.
For some reason the small i, was not being displayed. Did a Reboot and finally got it going.
Now able to Save Addresses again.
B52 :
