Dedicated forums for Garmin Zumo motorcycle satellite navigation. All questions answered from problems, route planning, touring to tips and tricks https://mail.zumouserforums.co.uk/
Hi, is any way to downgrade Zumo 595 from FW 4.60 to 4.40?
In 4.60 is a bug with selecting "Favorite POI" from map. ( see )
Garmin-support says : "After further investigation, it appears we had a case open regarding this issue. Sadly this issue will not be corrected at this time"
I tried the procedure for change 590 to 595, but I was not successful...
Re: 595 FW downgrade
Posted: Thu Aug 29, 2019 1:59 pm
by sussamb
Do you have a copy of your previous gupdate.gcd? If not Google Garmin Perry, you can get previous software updates there.
Posted: Thu Aug 29, 2019 4:18 pm
by bolek
unfortunately, when I save GCD file (I tried FW 4.40 and 4.30 from Perry) on SD card, then after restart Zumo asks : The software on the device is newer than the one you are installing - do you want to continue? I set YES, installation is in progress, but after restart it asks exactly the same. When I finally give NO, after Garmin starts up, it reports that the 4.60 update has been installed ...
I used this method on Garmin Oregon, but it doesn't work for Zumo... Am I doing something wrong?
Posted: Thu Aug 29, 2019 7:41 pm
by sussamb
Not sure but I'd try it on the device rather than the card
Posted: Thu Aug 29, 2019 7:49 pm
by bolek
when I tried it on the device, nothing happened - Zumo did not report an update. It only found it on an SD card...
Posted: Fri Aug 30, 2019 5:10 am
by sussamb
On the device it needs to go in the .system folder, that's normally a hidden folder.
Posted: Fri Aug 30, 2019 5:24 am
by bolek
Oh, thanks! I'll try it when I get home after the weekend.
Posted: Sat Aug 31, 2019 4:17 pm
by Vespamarc
I have 4.60 also and don't have problems with my favorite POI, everything works perfect here.
Posted: Sat Aug 31, 2019 6:08 pm
by mzeist
your favorite POI screen icons seems very small, may be a factory reset will sort things out?
I run 4.60 without problems.
Posted: Mon Sep 02, 2019 6:44 am
by bolek
[mention]sussamb[/mention] : Big thanks! With .system folder downgrade works, and now, I can use my favorites without restrictions !
[mention]Vespamarc[/mention] and [mention]mzeist[/mention] : Factory reset did not help... This bug is confirmed from US Garmin, maybe it only involves some revisions...
