Page 1 of 2
Zumo 396 Audio
Posted: Sun Oct 27, 2019 7:24 pm
by UncleBucket54
I currently own a Garmin Zumo 395LM. To receive audio output from the unit, I have a pair of Custom Fit earplugs, which I plug into a jack socket at the bottom of the unit.
My questions are:
• Does the Garmin 396 have this jack socket?
• Do the high end Zumo units have this socket?
Thanks in advance.
Re: Zumo 396 Audio
Posted: Sun Oct 27, 2019 7:56 pm
by Stu
not sure what the 396 has but the 590 and 595 has a mount with many wires for connection
https://www.getgeared.co.uk/garmin-zumo ... pnEALw_wcB
Re: Zumo 396 Audio
Posted: Mon Oct 28, 2019 7:32 am
Zumo 396 manual here....
http://static.garmin.com/pumac/zumo_396_OM_EN-US.pdf
I cannot see one.
BUT. The 395 manual does show an audio out jack
http://static.garmin.com/pumac/zumo_395_OM_EN.pdf
And the 595 manual which shows and labels the cable and connectors on Page number 1
http://static.garmin.com/pumac/zumo_595_OM_EN.pdf
The 590 has the same wired connections. I have one.
Re: Zumo 396 Audio
Posted: Mon Oct 28, 2019 9:23 am
by Dusty ST
I have a 395 and a 396, there's no audio socket on the 396.
Re: Zumo 396 Audio
Posted: Mon Oct 28, 2019 10:45 am
by tojjer
Confirmed, bluetooth only on the 396 for earphones, headsets etc.
Only two things you have access to on the back of the unit, is a rubber cover which pulls back to charge the unit or connect to a pc, and the larger rubber cover for the microsd card
Re: Zumo 396 Audio
Posted: Mon Oct 28, 2019 12:10 pm
by Oop North John
Garmin's motorcycle mount only shows a power input I think:
https://buy.garmin.com/en-GB/GB/p/pn/01 ... 1#overview
You could easily get a Bluetooth receiver and plug it into your ear buds, something like:
https://www.ebay.co.uk/itm/3-5mm-Mini-W ... SwJnxctsi0
590 / 595 motorcycle mounts have a line out lead:
https://buy.garmin.com/en-GB/GB/p/148672#overview
Re: Zumo 396 Audio
Posted: Mon Oct 28, 2019 8:07 pm
by pidjones
Let me advise to NOT waste money on ebay Bluetooth receivers. One was DOA, another lasted about 300 miles. Buy on from Amazon (not one of their vendors) so you at least have a 30 day warranty. I ended up buying a Bluetooth receiver that is powered by my bike and boots up when it powers up.
Re: Zumo 396 Audio
Posted: Tue Oct 29, 2019 4:07 am
by CollingsBob
I use a Cardo Freecom 1 to listen to music or phone calls from my iPhone and directions from the Garmin Zumo 396. The only issue that I havent been able to solve is equalizing the volume between phone and GPS. If the phone volume is correct (quite loud as I am partially deaf) then the GPS is excruciatingly loud to the point of distortion.
Battery life is quite good ...7-8 hours are no problem.
Re: Zumo 396 Audio
Posted: Wed Oct 30, 2019 12:14 pm
by Dusty ST
You can set volumes for GPS and phone independently.
Select volume then the spanner, you should see a volume slider for each output.
Re: Zumo 396 Audio
Posted: Wed Oct 30, 2019 12:46 pm
by CollingsBob
Dusty ST wrote: ↑Wed Oct 30, 2019 12:14 pm
Is this done on the Cardo app?
