Firmware update v.5.20
Having problems with your BMW navigator 6? then please post here with any sat nav, software, mount or cradle problems.
kebo
Slovakia
Post by kebo »
Just in case if you did not realized it yet - there are 3 new updates on Garmin Express for NAV VI:
Firmware version 5.20:
Changes made from version 4.90 to 5.20:
Added user consent for Travel History tracking per GDPR compliance.
Completed software modifications required to support Giantplus display configuration
Updated default brake debounce interval to 1 second from 10ms
Fixed an issue where if the power button was pressed shortly after the motorcycles ignition was turned 'off', the Navigator would permanently disable the screen
Greatly reduced the occurrence of phone audio echo
Removed 'Postal Code' from city search sample text
Added a new 'All Songs' option to the iPhone media source when browsing artists. This will allow user to select music which does not have an album tagged
Fixed a bug which caused teh Navigator to play BT phone audio to a headset even though it was muted
Modified 'Wipe All User Data' feature to remove all non-standard files and folders from the root directory of the devices
Removed duplicate text that can occur in imported POIs
Prevents music from playing automatically when a BT device disconnects and quickly re-connects
Removed a requirement for the user to acquire a GPS lock before EULA acceptance can be accomplished
Fixed a bug which prevented anonymous calls from working with newer iOS devices
BMW Motorrad Navigator VI Text:
v.1.50
Voice, American English-Samantha (TTS3)
v.2.60
No extended functions to be added like f.e. Garmin Adventurous Routing, may be next time...
kebo
Slovakia
Re: Firmware update v.5.20
Post by kebo »
New Firmware avalable from today:
Changes made from version 5.70 to 5.80:
Fixed an issue that could cause audio navigation prompts to repeat in a playback loop.
