Basecamp 4.8.7.0 Avaialble
Posted: Fri Dec 20, 2019 10:46 pm
by carolinarider09
Just downloaded this version. Have not verified it yet. The program does open up though.
Re: Basecamp 4.8.7.0 Avaialble
Posted: Mon Jan 06, 2020 8:42 pm
by midlife
I made the mistake of updating to 4.8.7 on my applemac, since then I only get a 1/4 screen in 3d. Garmin told me to uninstall and had to uninstall basecamp app, then go to library and uninstall com.garmin.basecamp.plist and then re-install.
I now have lost all my routes and waypoints and the 3d view still is faulty.
be careful and dont do what Garmin suggest bloody useless
Graham
Posted: Mon Jan 06, 2020 10:58 pm
by sussamb
I think I replied to you on another forum, but an uninstall and reinstall of BC doesn't delete databases. However if you'd set a location other than the default you'll need to reselect the correct database.
