slow reading of SD card?
Posted: Mon Jan 20, 2020 10:21 pm
by danham
I keep a lot of routes (more than 150) on my SD card and it was getting slower and slower. Today I went to add some new routes for an upcoming trip and when I hit "Routes" under "Import Data," it took about 6 minutes to populate the screen with choices and none of them were the GPX files I had just added using a card reader on my iMac.
After a bunch of reboots and other thrashing around, I decided to make a backup of all the data on the card and to use the excellent sdcard.org formatter to start fresh.
Success! It reads the files much faster and the new data was right where I put it.
Hope this helps someone.
Re: slow reading of SD card?
Posted: Tue Jan 21, 2020 12:58 am
by carolinarider09
danham wrote: ↑Mon Jan 20, 2020 10:21 pm
Do you have a reliable place to download the program?
Posted: Tue Jan 21, 2020 6:32 pm
by danham
carolinarider09 wrote: ↑Tue Jan 21, 2020 12:58 am
Yes, links on this page for both Mac and Windows versions...
https://www.sdcard.org/downloads/index.html
Posted: Wed Jan 22, 2020 1:32 am
by carolinarider09
Thanks.
I downloaded both. I run a Windows 7 environment on my Mac so I might try both. Have not installed them yet.
