Routing on the PC
Posted: Mon Mar 09, 2020 3:29 pm
by robbo12
When I Make a route on the PC (Windows 10) the calaulacted route is not on the road but parallel to it. This is something new Basecamp 2020.2 used to show the route correctly. any suggestions?
Robbo12
Re: Routing on the PC
Posted: Mon Mar 09, 2020 4:39 pm
by kernowing
If you select "Maps" in the task bar, what's showing the check mark?
Posted: Mon Mar 09, 2020 4:52 pm
by sussamb
This often happens if you've accidentally rotated the map. Select the compass icon and rotate it so it points north, that should resolve it.
Posted: Mon Mar 09, 2020 5:43 pm
by Breezly
What sussamb said. Or Use the pull down menu: View / Align North Up.
I seem to do this more frequently than I like when I'm using the track pad on my laptop instead of a mouse.
Posted: Mon Mar 09, 2020 5:49 pm
by robbo12
Thank's that solved the problem.
Robbo12
Posted: Mon Mar 09, 2020 6:40 pm
by sussamb
Great
