Page 1 of 2
Charging while in mounting bracket?
Posted: Wed May 27, 2020 7:27 pm
by Ae1m
When I connect the XT via USB, I see the lightning bolt through the battery indicating that the battery is charging. When I connect to 12V via the mounting bracket I do not see the lightning bolt. However, the GPS does turn on when I connect the mounting bracket to 12v indicating to me it is recognizing the power.
Should the battery be charging?
Does yours exhibit this behavior?
Bob
Re: Charging while in mounting bracket?
Posted: Thu May 28, 2020 2:45 pm
by simoncrewe
Just been out to the garage & put the XT on my KTM and I get the lightening bolt on the battery symbol.
The unit also fires up the minute it goes in to the mount.
Posted: Thu May 28, 2020 3:26 pm
by Ae1m
Odd.
My unit fires up, but no lightning bolt
Bob
Posted: Thu May 28, 2020 4:00 pm
by simoncrewe
Ae1m wrote: Thu May 28, 2020 3:26 pm Odd.
Bob
Might be worth having a look at the pins in the power cable, there have been a number of reports of them going bad/breaking.
Posted: Thu May 28, 2020 7:55 pm
by Ae1m
Thanks, this is with 2 different new version mounts and all looks fine.
The odd thing is that the unit powers on when connected, but no lightning bolt and the unit eventually dies while riding. Not getting power.
I cut off the Garmin fuse attached to the harness because I connected directly to an port on my handlbars that is already fused if that matters.
I verified +12V on the pins. The third pin down has +12 and the bottom pin is GND.
Bob
Posted: Thu May 28, 2020 7:58 pm
by cr0100
The fact that it's failing to charge in multiple mounts (behavior follows the device) suggests the issue is with your device, unfortunately.
Posted: Fri May 29, 2020 12:58 pm
by iankim
I am no expert but I thought the black box job was to drop the voltage to 5v?
If it has been removed and you have 12 v going into the XT that might be the problem.
Posted: Fri May 29, 2020 1:31 pm
by Ae1m
That was the problem. I was told by support that it was just a fuse and I didnt need that since I was connecting to a fused connector. Put the box back and now OK.
Posted: Sat Jun 13, 2020 8:15 pm
by Robiwan
I cut the black box (transformer)off mine and soldered on a USB plug to go to the USB port works fine
Posted: Sun Jun 14, 2020 8:37 pm
by TripleThreat719
Robiwan wrote: Sat Jun 13, 2020 8:15 pm I cut the black box (transformer)off mine and soldered on a USB plug to go to the USB port works fine
That is because a standard USB port supplies 5V of power, not 12...
Cutting off that black box on the XT power cord and wiring it directly to a 12V (i.e. battery tender or cigarette lighter) connection will not work.
