Own typfiles on Zumo xt?
Posted: Fri Jul 24, 2020 6:58 pm
by yamaha07
In meny Garmin device you can use own typfiles but not in Zumo xt, someone who has a solution? Garmins topo map are horibble without retyping
Re: Own typfiles on Zumo xt?
Posted: Sun Jul 26, 2020 9:59 am
by mzeist
the XT uses themes not typ files. According to this page:
https://www.pinns.co.uk/osm/theme_editor.html the TYPWiz editor can convert typ to themes.
I have not tried this myself yet, I did however edit my themes.
Look for some more info about editing themes in this thread:
viewtopic.php?f=48&t=730&p=4641&hilit=themes#p4641
Posted: Sun Jul 26, 2020 5:12 pm
by yamaha07
I want the old time back with typfiles, but thank you for your explanation
Posted: Sun Jul 26, 2020 7:27 pm
by mzeist
I hope you can find out if converted .typ files will work on the XT
would you be willing to share your .typ file from ts post? looks much better than the garmin version!
Posted: Wed Aug 19, 2020 9:44 am
by HMR
Typefiles for various maps are here. Currently not tested on Z-XT....
http://resmark.se/gps/hmrtyp.zip
Posted: Thu Aug 20, 2020 8:30 pm
by HMR
I have now tested installing own typfiles in maps to be used on Zumo XT.
It works fine. The installation procedure is not different from what you use with other Garmin models. But the map needs to be licensed for the GPS.
Within a few days you can download typfiles for Zumo XT for City Navigator 2021.1 and Swedish Topo PRO V6 from
Posted: Fri Aug 21, 2020 6:22 pm
by yamaha07
Nice very nice you are my hero
Posted: Thu Aug 27, 2020 8:06 am
by HMR
