Off-Route Calculation question
Posted: Sat Jul 25, 2020 4:37 pm
I've just got rid of my TomTom Rider 400 because it gave me all sorts of problems so I've replaced it with a Garmin Zumo 595. If I imported a track to my old TomTom and strayed off of it at all for any reason such as a wrong turn or impromptu stop somewhere it would just absolutely freak out and try to send me all over the place and sometimes even try to send me back home instead of continuing on the track.
I don't want that same particular problem with the Garmin so I need to make sure I'm using it correctly, what I've done is create a track using MyRoute-App (Free browser based version) which has just 12 waypoints and exported it directly to my Garmin as a GPX 1.0 file (for some reason when I try GPX 1.1 the Garmin must recalculate my track as it changes the track a lot when imported?!). The track then shows up in my Garmin under Apps/Tracks as expected.
So if I set off on this track with Off-Route Calculation set to AUTO and happen to stray off of it for some reason what will happen:
Will the Garmin try to get me back on the closest part of the track and then continue the exact track?
Make me go back to the previous missed waypoint?
Try to get me to the next waypoint?
None of the above?
I read somewhere on here that someone said that they usually have Off-Route Calculation set to Prompted so they would be alerted via a pop-up that they'd strayed off of their track then they just hit Ignore and kind of manually navigated back to the track by looking at the screen, this could work for me as a last resort. It would be nice if in the event I stray off of my track that the Garmin would simply get me back on the nearest point of the track automatically without making me do u-turns or have me go back to a waypoint I missed by accident, is this possible?
Just to add I also have Tyre installed as I find that nicer to create routes on so sometimes I save the GPX file from Tyre and then Import it into MRO in order to send it to my device. (Tyre wont recognize my Garmin for some reason). The version of Tyre i have is v7.0 because it does not require you to set up an Google API.
None of the above?
