Page 1 of 2
XT_Alerts on Map
Posted: Thu Aug 13, 2020 9:47 pm
by larryg
When driving I get Icons on the map, showing nearby restaurants and banks,
but seldom (if ever) see gas stations - even I'm when driving right by them.
How or where do we set what "Icons" for these appear on the map ?
I really don't care about banks, I'd mostly just like to see restaurants and gas stations.
Where can I select which alerts display on the map ?
Thank you....
Re: XT_Alerts on Map
Posted: Thu Aug 13, 2020 9:51 pm
by sussamb
Tap the icon, then when you have the list up tap the spanner icon and you can then customize the list
Posted: Thu Aug 13, 2020 10:20 pm
by larryg
sussamb wrote: Thu Aug 13, 2020 9:51 pm Tap the icon, then when you have the list up tap the spanner icon and you can then customize the list
I will try that, next time I ride, apparently the icons don't display off the bike.
Will tapping the icon bring up the "Up Ahead" settings? I ask because trying that (parked) I can't get anything to change.
Thanks...
Posted: Fri Aug 14, 2020 5:59 am
by sussamb
They should show off the bike, are you selecting Up ahead from the menu?
Posted: Fri Aug 14, 2020 7:03 am
by Vespamarc
Customizing the Map Layers
You can customize which data appear on the map, such as icons for points of interest and road conditions.
Select Settings > Map & Vehicle > Map Layers.
Select the layers to include on the map, and select Save.
Posted: Fri Aug 14, 2020 10:44 am
by simoncrewe
larryg wrote: Thu Aug 13, 2020 10:20 pm
Thanks...
Page 12 of the owners manual.
Posted: Fri Aug 14, 2020 5:18 pm
by larryg
sussamb wrote: Fri Aug 14, 2020 5:59 am They should show off the bike, are you selecting Up ahead from the menu?
Yes, I am selecting Up Ahead.
Off the bike, I see no icons on the map - even though displaying an area nearby with multiple restaurants.
Again, I saw tons of icons while riding recently (but no gas stations).
Posted: Fri Aug 14, 2020 5:26 pm
by larryg
Vespamarc wrote: Fri Aug 14, 2020 7:03 am Customizing the Map Layers
When I do this, it brings up the same three things I see when clicking on the map (3 dots),
Motorcycle Locations
Banks & ATMs
Restaurants
In neither location do I see how to add or delete items that will display, only arrows to move them up or down on the list.
This shouldn't be so convoluted, but:
Thanks for all the help !
Posted: Fri Aug 14, 2020 7:02 pm
by sussamb
Just tap the one you want to change, so the screen where you see the up/down arrows just tap the text ...
Posted: Fri Aug 14, 2020 8:07 pm
by larryg
sussamb wrote: Fri Aug 14, 2020 7:02 pm Just tap the one you want to change, so the screen where you see the up/down arrows just tap the text ...
OK, I think I've figured it out. :D
Apparently you can only select three things, so to delete one you have to do a Custom Search on that item to replace it.
So, all good here now, thanks for all the help !
