Basecamp Newby (Ish)
Scarecrow
Been liked: 24 times
Post by Scarecrow »
Ok. So I've started to use Basecamp to plan some route as I'm in the market for a XT and I'm told it doesn't support Mapsource (Shame I like Mapsource)
My question is How do I remove the route I from the Basecamp map without deleting it from the Route folder.
ray6576
Been liked: 9 times
Re: Basecamp Newby (Ish)
Post by ray6576 »
Go to this web site for information about Basecamp: https://www.newenglandriders.org/category/gps/
Has liked: 344 times
Been liked: 368 times
BaseCamp is a database. What is shown is a link to the data, so you can have the same item in more than one folder or list should you wish to. To 'remove' a route from the map select a folder or list that doesn't contain the link to it.
