I have just discovered a map error on my XT
While reading this thread viewtopic.php?t=1634 and doing some testing I was seeing what differences I would get compared to google maps with fastest route calculations
Anyway searching for and getting directions for York (UK) the XT shows this road as York and not the city!
Clicking on the road in google maps also shows it as York!
https://www.google.com/maps/place/54%C2 ... d-1.397733
Does anyone else's zumo do this?
Map errors!
Re: Map errors!
Mine does exactly the same thing. And Basecamp. Clearly a mapping issue.
Now York have a traffic problem and seem to be addressing it by stealth. But getting the maps to show York to be 15 miles to the north west of its actual location is a tad sneaky. That is one heck of a Park and RIde journey.
A good road to ride, by the way. It is the old A1, runs parallel to the A1(M) . Brilliant for a traffic free motorcycle ride.
There is a similar parallel road alternative from near Ferrybridge to Scotch Corner.
- Site Admin
- Has liked: 438 times
- Been liked: 266 times
Re: Map errors!
@jfheath and anyone else
Feel free to report it to garmin to see if they correct it
I try to avoid motorways full stop so usually end up on some roads like those at some point
Re: Map errors!
No. I won't send that one in ! I know where York is.
It would be my luck for them to fix that and not the other collection of issues that I have sent them.
John
John
- Site Admin
