Latest XT Motorbike Lockable Mount options
Re: Latest XT Motorbike Lockable Mount options
Richard_R wrote: Sun Feb 27, 2022 9:44 pm No screen saver required. If the GPS falls off the bike at speed or you crash a screen saver is going to do nothing to save the GPS. In normal use how would you damage the screen?
I had a nuvi that needed the touch screen and digitizer replaced. You'd be surprised how damaged the touch was. I use a screen protector now and after 2 or 3 yrs it requires replacement. I guess it's the minute grit in glove material.
The key word there being "may". If it does then remove it. If it doesn't you're golden.
Scarecrow
Been liked: 28 times
Post by Scarecrow »
simoncrewe wrote: Mon Feb 07, 2022 5:25 pm I have the Touratech mount, by far the most secure, as it surrounds the body of the XT & prevents the unit popping off the flimsy mount.
By the time you look at the Zumo lock & postage, you may as well buy the TT mount.
I have a mount cover with a KTM logo on mine when the unit is not installed - looks fine.
Hi Simon
Where did you get the mount cover
Been liked: 265 times
Scarecrow wrote: Tue Mar 01, 2022 8:02 am
Hi Simon
If you know someone with a 3D printer I have the file to make them
Edit: here you go https://www.thingiverse.com/thing:4546658
@Scarecrow There is also these https://www.gps.nl/motornavigatie/zumocoverxt.html
I bought two of these and they are pretty good
colirv
Has liked: 66 times
Been liked: 64 times
Post by colirv »
Stu wrote: Tue Mar 01, 2022 2:44 pm @Scarecrow There is also these https://www.gps.nl/motornavigatie/zumocoverxt.html
Yep, work well.
Colin
BMW R1250RS
https://www.namrider.com
Zumouser34
Post by Zumouser34 »
Scarecrow wrote: Mon Feb 28, 2022 4:35 pm hi Guys
How does the Zumo lock work
e.g. Does it lock the mount release button or does it just stop access to the ram mount.
Might be me but I cant tell from the pictures.
As stated in the earlier post I have the Tourtech locking mount but its very shaky when riding.
It swings a tab out under the Zumo release button so you can’t press it.
groundhog719
Has liked: 12 times
Been liked: 5 times
Post by groundhog719 »
I have the ZumoLock on 2 bikes (Multistrada and XR650L). I would rather have the Touratech as it locks the entire GPS instead of relying on the seemingly anemic plastic Garmin mount. However, the Touratech was back ordered and not available when I got the Zumo XT. I custom made aluminum mounts for the ZumoLock to attach to the bike.
ian_h
Post by ian_h »
Just to close this out - just installed the Zumolock on my Multistrada.
Needed to change the mounting holes I was using for my Garmin to get enough clearance under my screen - but otherwise pretty happy.
This won't stop a determined attack obviously, but I'm happy enough to use this when leaving my bike for short periods.
