Won't connect to computer
mauritswoudenberg
Post by mauritswoudenberg »
Hi all,
As I mentioned in my previous post and currently on a round the world trip on my motorcycle.
My 595 does not want to connect to the computer. WHen I plug in the USB cord it shows the orange computer / gps connection image but then it restarts and acts loike it's just charging and not connected to a computer.
Does anyone know how to fix this? It's the same for mac and windows and with different cords / computers.
Hope anyone can help!
Best,
Maurits
Has liked: 414 times
Been liked: 901 times
Re: Won't connect to computer
The best I can suggest :
The cable needs to be Charge and Synch - not just charge. I have one cable that does what you describe.
Maybe the USB connector is not making good contact. Try holding it in position with a bit of pressure on one side - see if it makes a difference.
I've just moved my cable around where it plugs into the 595, and it disconnected from the computer, having been showing the Orange computer on the screen.
Check that you don't have other programs running on you computer that are trying to access the USB (Garmin Express and Basecamp have issues when they are both run together).
Check the type of connection in the settings
Main Screen / View Map / Tap Speed button, bottom left / Tap and hold the circular speedo display top centre. 10 seconds.
This enters Diagnostic Page
Configuration and Settings / MTP Settings
There are three options. Typically it will be set to MTP Auto Detect.
Others are Mass Storage
MAss Storage single Session
MTP is media Transfer Protocol. The Zumo behaves like a media device and can be conencted and unplugged at will
Mass Storage - the device behaves like a disk drive and gives you one or two new drive letters.
If one isn't working, the other might.
The single session options runs Mass Storage the next time it starts up, and then the next time after that, it goes back to MTP.
mauritswoudenberg
Hi,
Thank you for your suggestions.
Unfortunately I ruled out cable & computer. I also tried some light pressure on the usb contact, but it didn't work. I think the usb connection is fine because it does recognize a computer (orange pc screen, and grey pc screen when selecting mass storage. The zumo just restarts itself and then boots into normal startup like its only charging.
Any other options that anyone can think of?
Thanks again!
It displays the computer on the screen before it has started the connection to the computer. So it is recognising that the cable is connected to something. But then it doesn't establish communication - so it suggests that the connector or the cable is dodgy to me. Especially since mine does the same thing if I use a particular cable and disturb it. I have to put the Zumo screen face down so that the cable is sticking straight up and cannot be disturbed. I don't know if the issue is with the connector, the wire or the soldered joints on the circuit board.
I just know that I keep the number of times that I plug the cable into the Zumo to a minimum. I leave the cable in at the Zumo end and disconnect from the PC when I am using it.
Has liked: 109 times
Been liked: 252 times
The other thing I found is the computer's usb ports. My laptop has 3 but 1 is useful for 595 charging only, no comms. I have to use one of the other two for comms with Base Camp to work.
mauritswoudenberg
I'm a bit embarrassed to say this but I think it was indeed the cable... I brought 3 micro USB cables with me, and all of them worked for both charging and data on multiple devices (e-reader, card-reader), but after trying a borrowed fourth one it actually did connect.. My bad, thanks for convincing me to keep suspecting the cable.
Cheers!
No problem, I'm glad that it worked.
And thank you for feeding back - it helps others who are reading the posts in the future to try different things.
I have 5 of these cables - I have a number of devices that use the same style of connector. One of them doesn't work for data. One day I will remember to label it. But where's the fun in that.
RobWCanada
Post by RobWCanada »
I know you seemed to have resolved this with a new cable. But I was having the exact same issue with Garmin Express and my Mac running "Catalina" (old yes, it's a 2013 Mac but still going strong!)
Anyway, I was using the supplied Garmin cable to connect, I always keep this around because it is true that the Garmin's are very finicky with the USB cable selection. But anyway, I was still not able to connect.
SOLUTION:
Step 1: Drag Garmin Express to the trash bin (or un-install on Windows)
Step 2: Download Garmin Express from Garmin.com
Step 3: Done. Zumo XT was connected.
** Not only did this work, after removing and re-installing I didn't even restart the computer OR unplug the Zumo XT from the laptop. As soon as the Garmin Express software was re-installed everything worked as expected.
Also, previous connections were also still there. Prolly cause library settings weren't removed. Only the application was dragged to the bin.
simple, hopefully it helps others. Sometimes the solution is the easiest one.
R
Has liked: 372 times
Been liked: 382 times
You probably weren't running the latest Express
Alexontwowheels
Post by Alexontwowheels »
So, I spent days trying to connect as well, tried 3 different cables, updating the software….. everything.
This sounds weird, but I seem to have figured out that there is an EXACT sequence to follow, and now it connects EVERY time. Hope this works for you too!
- Connecting to Mac
1. Garmin express CLOSED
2. Plug cable into port
3. Plug Cable into Zumo
4. Wait for Zumo to go into pairing mode
5. Launch Garmin Express
- Disconnecting
1. Close Garmin Express
2. Disconnect device from computer
