previous Maps
Scarecrow
Been liked: 28 times
previous Maps
Post by Scarecrow »
Do i need to remove previous versions of CN EU
from my xt
if so How do I do it
Thanks in advance
Re: previous Maps
Express should do that automatically IF it installed the previous maps and you haven't changed their locations or names.
Scarecrow
Re: previous Maps
Post by Scarecrow »
OK Thanks
Just when I look at my Maps on the XT the previous version is still listed :?
Re: previous Maps
Scarecrow wrote: Fri May 20, 2022 8:02 am Just when I look at my Maps on the XT the previous version is still listed :?
Is the new one listed too?
Edit: How about in Express; previous and current, current only, both?
Re: previous Maps
Scarecrow wrote: Fri May 20, 2022 8:02 am OK Thanks
Hmmm ... so was that previous version installed by Express? If so was that Express version on your current PC or a previous one?
Assuming nothing changed Express should have deleted the previous map.
Scarecrow
Re: previous Maps
Post by Scarecrow »
OK All good now only the new maps are on XT
Together with the following
CN Europe NTU 2030.10 Foursquare
CN Europe NTU 2030.10 Parkopedia
Europe DEM
TopoActive PS Europe 2021.10 North East
TopoActive PS Europe 2021.10 Central
TopoActive PS Europe 2021.10 West
So do I need the above of can they be deleted and if so How
Re: previous Maps
You can but why bother?
Foursquare is a poi database
Parkopedia is parking details
DEM is the Digital Elevation Map
The others are topo maps
Scarecrow
Re: previous Maps
Post by Scarecrow »
sussamb wrote: Sat May 21, 2022 7:20 am You can but why bother?
Just thought it would free up room :D
Re: previous Maps
Well removing the topo maps might but do you need room for something?
