Reverse a routes- ZUMO XT
Raf
Has liked: 14 times
Been liked: 3 times
Italy
Post by Raf »
good morning!
How can I reverse a route on the XT?
Thank
Rofor
Has liked: 169 times
Been liked: 74 times
Austria
Re: Reverse a routes- ZUMO XT
Post by Rofor »
Sadly this is not possible on the Zumo XT... :roll:
Bye, Robert :)
TripleThreat719
Has liked: 5 times
Been liked: 31 times
Post by TripleThreat719 »
It is possible, but not as easy as past models...
If you export a gpx file of a track to Explore, you can open the track using the Explore icon on the Zumo and then convert the track to a trip. When choosing to convert a track to a trip, the XT will ask you if you want it start to finish, or finish to start. You will end up with two saved trips if you convert to track to a trip in both directions. you will then use the Trip Planner to access it under saved trips...
Rofor
Austria
Post by Rofor »
Ok - what i mean was not on the Zumo XT directly! 8-) And - 'Garmin Explore', so i'm out here - it's a no-go for me... :?
Bye, Robert :)
HipGnosis
Post by HipGnosis »
I can sorta help you - I've done it, but not recently so not exactly sure on the steps.
Before you start riding your route, start tracking; @ main screen, track [start]
At the end of your route, Stop tracking, save the track (w/ a name).
To ride it reversed; Apps Tracks {track name} [go] [ finish to start ]
It's Hip, ya Gno?
Raf
Has liked: 14 times
Been liked: 3 times
Italy
Post by Raf »
ok!
I already have the tracks.For each routes I have a track.
Fxwheels
Has liked: 30 times
Been liked: 30 times
Post by Fxwheels »
There are several ways to ride the route backwards after riding it. The ultimate question is if you can reverse a route in the XT just by reversing directions as you'd do in BaseCamp. The short answer is - no. Though possible in others older units.
Has liked: 371 times
Been liked: 380 times
HipGnosis wrote: Fri Jul 08, 2022 9:45 pm I can sorta help you - I've done it, but not recently so not exactly sure on the steps.
Even that can cause issues when you hit divided roads, one way streets etc
Has liked: 108 times
Been liked: 252 times
sussamb wrote: Sat Jul 09, 2022 5:56 am Even that can cause issues when you hit divided roads, one way streets etc
My thought exactly. I think I'm always better off creating a separate route to ride in each direction. Divided highways especially will create all sorts of u-turns and confusing loops. Sure, I suppose I could just "ride through them" but why deal with the aggravation?
For the times I do want a reversed route, I pre-plan with Base Camp by right click, duplicating, renaming, then modifying to put all the points where they should be. I refuse to use Explore as well.
Fxwheels
Has liked: 30 times
Post by Fxwheels »
You want all of the good features, buy Garmin Montana
