Route planning frustrations!
Been liked: 266 times
Re: Route planning frustrations!
sussamb wrote: Mon Jul 11, 2022 1:52 pm Strange. Plotted in BaseCamp using the driving profile there aren't any issues, only a strange route if you select the motorcycling profile. Even the RV profile routes correctly.
That is strange!
Like @Peobody said I wonder if we would be better using a different profile :?
Probably. The key question is if you do does it then give you the correct route on the XT? I don't have one so can't check.
Also would be worth looking at the differences between the motorcycling profile in BaseCamp and try to determine which of the options are creating the issues.
@sussamb Unfortunately I can't change that setting in MyRoute App
The "driving" profile covers cars and bikes well anything driving really
The only other options are cycling and walking
I would have to import the route to basecamp and check it there
Which I did do and on the driving option it shows the route correctly
I should add that when you import it to basecamp you get straight lines between each point and recalculating it shows the correct route! not with the huge detour
eureka!!
Found the issue! Google and TomTom maps are correct and Here maps is wrong :roll:
Here maps shows it as no through road when in fact it is and even on street view it shows cars on it :lol:
2022-07-11 16 46 13.png (67.34 KiB) Viewed 1494 times
Yet BaseCamp allows routing using the activities I mentioned above. Either Garmin is using an earlier HERE map or Garmin have corrected it.
The issue still exists that Basecamp produces a different route with the Driving profile vs. the Motorcycle profile right?
This is a Basecamp specific question but since we're talking about it, does anyone know if there are any differences in those two profiles that we don't see in the configuration options?
Peobody wrote: Mon Jul 11, 2022 9:03 pm The issue still exists that Basecamp produces a different route with the Driving profile vs. the Motorcycle profile right?
This I can't answer as I use MyRoute App for planning the route but when exported it and opened it up with basecamp it recalculated to be fine
It could just be an issue with MyRoute App and not Basecamp or the Zumo
I need to look in to it more but I am going away for 4 days tomorrow so won't have chance yet
OK I tell a lie! I thought I would have a quick look before I head off to bed
In basecamp if you have avoid state highways ticked it won't allow you down it but untick it and it works fine
I've heard this before and never really believed it as I have never been able to demonstrate it.
Are the settings for the Driving Profile and for the Motorcycle profile identical ?
