Help connecting devices please
Wedders_gasman
- Has liked: 1 time
- Been liked: 3 times
I have a Zumo 590, an iPhone 12 and a Sena SRL, and can’t get them all working together. I decided I would run everything through the Zumo but it just won’t work. They will all connect together but will only work when connected individually. e.g. if I want spoken directions from the Zumo I have to turn the Bluetooth off on the phone. If I want the phone connected I have to turn off the Zumo they just refuse to work together. Anyone got a magic wand?
Re: Help connecting devices please
Check this out.
I know that it is written for a cheapo BT headset, but the same priciples still apply. I know it helped someone trying to get a Sena a 590 and a phone to talk to each other.
The key thing is to start with a clean sheet and turn off EVERYTHING in the house that the devices have ever paired with, and delete the pairing (and any knowledge) of any other device from the phone, the 590 and if possible the headset. I'm just saying it here to point out how important these steps are. They are tedious, but if you take shortcuts, it might fail.
- Zumo 590 and Bluetooth.pdf
- (1.67 MiB) Downloaded 527 times
Wedders_gasman
- Has liked: 1 time
Thanks for the info. Tried the full procedure clearing the pairing on all devices and re pairing as instructed. Unfortunately everything still the same.
