I would like to get a replacement battery for my Zumo 660. I looked at the Garmin website and could not find one.
I found other sites but I am not familiar with them so do not know the quaintly of the battery I would get.
So, where should I look for a replacement battery? Or, better yet, where is the most reliable place (besides Garmin) to purchase a new battery?
THanks.
Best Place To Buy Replacement Battery
- Has liked: 30 times
- Been liked: 39 times
- Has liked: 1 time
- Been liked: 37 times
Re: Best Place To Buy Replacement Battery
Have you tried here:
https://www.palmdr.com/
I have no personal experience, however I've heard/read many, many supportive comments and referrals to them.
I had not thought of him. And yes I have used his services and he did good work in both cases. Thanks.electro_handyman wrote: ↑Mon Oct 24, 2022 9:25 pm Have you tried here:
I will check.
And I just did and he does not have batteries for the 660 line. But I will send him a message just in case.
- Has liked: 120 times
- Been liked: 122 times
Amazon shows several vendors. Can't vouch for them, but Amazon is usually OK when it comes to returns if needed.
I did contact Chris Short (The Palm Dr. but the real name appears to be "Short Tronics") and he said just get one, as you suggested, from Amazon.
So, I will do that.
So, I will do that.
