Hi, I have a 550 but only the car mount.
Is there any other model mount that will take the 550, the 400 series for example?
Motorcycle Mount
- Has liked: 415 times
- Been liked: 903 times
Re: Motorcycle Mount
I don't know the answer I'm afraid. I know the 400s and 550 looked similar, but its a long time since I had a 550. I liked it at the time, but I was pleased when after the third failure, they had no refurbished ones left and sent me a brand new boxed 660. The cradles for the 550 will be kicking around somewhere - I assume - but it would take me a while to find them. Have you tried ebay ?Chromehead wrote: ↑Fri Oct 21, 2022 11:14 am Hi, I have a 550 but only the car mount.
I was just looking through unanswered posts. You've not had much luck with replies have you ? Sorry about that. Did you sort out the music file in your last post ? The Zumos pick up any music that is stored in the MP3 folder on both the SD card AND in internal storage.
- Chromehead
- Has liked: 1 time
Absolutely no luck on the mount so far, i'm constantly searching eBay, did you find any hiding in your garage?
The query on the SD card resolved itself - I took it out and now use my phone for music instead!
Thanks for asking.
Ian
Thanks for asking.
Ian
- Has liked: 1 time
- Been liked: 36 times
Let me look in my garage. I've had 2 mounts previously(one on each of my BMW K bikes), but as one bike is now a parts bike and I have the XT to use now on any of my bikes I could probably be persuaded to part with one of them.Chromehead wrote: ↑Fri Feb 10, 2023 10:15 am Absolutely no luck on the mount so far, i'm constantly searching eBay, did you find any hiding in your garage?
Thanks for asking.
Ian
- Chromehead
- Has liked: 1 time
That would be great, if you do PayPal I would happily pay"friends and family" for any costs involved.
Ian
Ian
- Has liked: 1 time
- Chromehead
- Has liked: 1 time
- Has liked: 1 time
