Gas range warning pops up too much
Galanity
Post by Galanity »
I was on a long route (past gas range) and every minute or so I'd get a popup "Distance exceeds gas range, search for gas stops?" I'd click no, and a minute later the same message would appear. After clicking no about 10 times the messages finally stopped appearing.
Is there a way to prevent those warnings from appearing? I've read the manual but didn't see anything promising.
Has liked: 424 times
Been liked: 240 times
Re: Gas range warning pops up too much
I just turned fuel tracking totally off as it was just too annoying I just work on 250 miles and plan for fuel and stopping for the day
Has liked: 129 times
Been liked: 100 times
I think its "Apps" - "Fuel Settings" - and then "Unspecify" the distance per tank.
Has liked: 140 times
Been liked: 438 times
Stu wrote: Wed Oct 26, 2022 7:11 pm I just turned fuel tracking totally off as it was just too annoying I just work on 250 miles and plan for fuel and stopping for the day
Me too, although my planning is based on 150 miles.
HarveyM
Has liked: 10 times
Been liked: 9 times
Post by HarveyM »
Same, I just use the tripmeters instead. Plus my gas gauge flashes once it reaches 'reserve'.
Has liked: 418 times
Been liked: 908 times
I don't use it - I did on the 660 for a while, but it was not very accurate and not as useful as I thought it might be. And having to remember to reset it at each fill up was a pain. Although I think it recognised when you had stopped for fuel. Maybe that is my bad memory, or you had to set it as a destination.
Does the XT recognise when you stop at a petrol station and reset the fuel tank to full ?
Galanity
Post by Galanity »
jfheath wrote: Thu Oct 27, 2022 9:44 pm Does the XT recognise when you stop at a petrol station and reset the fuel tank to full ?
It pops up a message "Possible fuel stop detected, reset fuel range?"
