Not charging despite being connected directly to battery
thesexpistol
Portugal
Re: Not charging despite being connected directly to battery
Post by thesexpistol »
simoncrewe wrote: Fri Nov 11, 2022 10:47 am If you are getting 10 volts at the pins the cable is faulty. The little black box steps the 12 volt supply down to 5 volts for the XT.
Just noticed! the red lead on your multimeter is in the wrong hole! it should be on 'DC' not AC. Move it & retry.
Hey @simoncrewe! I also found it strange. I also thought it should read 5 volts.
I believe the red lead is connected the right place, it can detect up to 1000V DC. The 10ADC port is to detect more than 200mA (up to 10A in DC), which is not the case.
thesexpistol
Portugal
Garmin will send a 3rd cable... They said the multimeter is not supposed to read 10V, should be reading 5V. No shit...
