transfering files from internal storage to SD card
JulianDz
Post by JulianDz »
just got a good used zumo 550 and the internal memory is almost full.( cant update maps) how do I transfer files from internal memory to sd card?
Has liked: 371 times
Been liked: 380 times
Re: transfering files from internal storage to SD card
You shouldn't need too, Express should ask you to insert a card if one is needed. If it doesn't then please confirm that so we can advise further.
JulianDz
Post by JulianDz »
I put in a new 32gig SD card. With the Zumo connected to the PC, via Garmin express, it shows the amount of internal storage left. It shows the SD card and it's full available space. But when I try updating the maps it stops with the error message of internal storage being inadequate
Has liked: 414 times
Been liked: 901 times
Does the 550 accept cards that big ? Let me see if I can find out ....
No. Not according to this page. Scroll down and find the link to the Zumo info.
https://support.garmin.com/en-GB/?faq=U ... memorycard
It says that the maximum card size for the 550 is 4Gb. The software update log doesn't indicate that it was ever increased.
Correction. Version 3 software update. :
Added support for SDHC cards and increased MP3 playlist limit to 1000 songs.
No size limit given
Forgot that the 550 wont allow Express to access the memory card. To update the map see https://support.garmin.com/en-GB/?faq=b ... memorycard
Fallguy67
Has liked: 45 times
Post by Fallguy67 »
Instead of transferring files from the internal memory to an SD card, you may want to simply install the maps to the SD card. That's what I've been doing.
electro_handyman
Been liked: 36 times
Post by electro_handyman »
I use a 32Gb SD card in my 550, and have loaded the maps to the SD card, not the internal memory.
The new maps available are too large for the internal memory for a complete install.
I've got 2023.1 installed on my SD card and it's 3.3Gb in size.
JulianDz
Post by JulianDz »
ok, so what is the process for loading to the sd card? I used the option on down load and selected my pc. I created a folder on my desktop. do i just copy the files to the sd card or is something else need to be done?
Les
Has liked: 9 times
Been liked: 22 times
Post by Les »
I had a similar issue with my Zumo 660 (not recognizing SD card) I used 'Mapinstall' and it worked a treat.
JulianDz wrote: Sat Nov 26, 2022 3:10 pm ok, so what is the process for loading to the sd card? I used the option on down load and selected my pc. I created a folder on my desktop. do i just copy the files to the sd card or is something else need to be done?
All explained in the link I posted :)
