WiFi update downloads never work if Bluetooth is enabled
cr0100
Been liked: 17 times
Post by cr0100 »
Every time I fire up the XT to check for updates, the same thing always happens: I get the "Updating device. Do not unplug" message, and NOTHING HAPPENS.
After 4-5 minutes (trying to be patient), I then press and hold the power button to reboot it - and after going into the wireless/network settings and disabling Bluetooth, I once again go to check for updates and the download/installation proceeds without a hitch.
Is it only me? Is this a documented process, or what?
Re: WiFi update downloads never work if Bluetooth is enabled
Not a known issue AFAIK. My update function works when Bluetooth is enabled.
Having BT enabled on my phone reduces the data rate from my home wifi to a crawl, must be interference between the 2 signals, wonder if that's your issue?
cr0100
Post by cr0100 »
Interesting thought about interference. I have dual-band WiFi at home (2.4 and 5 GHz) but I'd wager the Zumo only uses 2.4GHz band, which is the prime range for interference from Bluetooth.
TripleThreat719
Has liked: 5 times
Been liked: 31 times
Post by TripleThreat719 »
No issue on my end with WiFi Updates while Bluetooth is enabled. Linksys Velop Mesh home tri-band wifi setup - Simultaneous Tri-Band (2.4Ghz + 5GHz + 5GHz)
Last edited by TripleThreat719 on Thu Jan 26, 2023 11:18 pm, edited 1 time in total.
roojim
Post by roojim »
I think it's definitely a local issue because everything works correctly on my end with Bluetooth enabled.
roojim wrote: Wed Jan 25, 2023 1:11 pm I think it's definitely a local issue because everything works correctly on my end with Bluetooth enabled.
Ditto. I was curious so I updated via wifi with Bluetooth on and connected to my phone with Garmin Drive app active. No problem with the update at all.
V-Tom
Has liked: 12 times
Been liked: 15 times
Post by V-Tom »
Just updated via wifi earlier this week no issue.
..Tom
