New maps for mapsource from Zumo XT
Re: New maps for mapsource from Zumo XT
Agree with@sussamb Update Mapsource, Map looks OK
css9101
Post by css9101 »
I remember at one point, there were issues with newer versions. Is this version stable or should I try to find the same version you are on?
Latest version has always worked for me, so suggest you try that first.
Use link I posted.
css9101
Post by css9101 »
It worked!!! Thank you!!!
Great :)
Thanks for the info.
For what its worth. It took me a long time to get used to Basecamp, and used Mapsource instead, But now I prefer Basecamp.
Les
Has liked: 11 times
Been liked: 25 times
Post by Les »
I'm one of those stuck in the past and much prefer Mapsource.. the last update was 6.16.3.
@Les
Yes, that's the one I linked to above and which resolved the problem
DavefromDenver
Has liked: 6 times
Post by DavefromDenver »
Your link to Mapsource only works to update. Where can I find the download of the original Mapsource? I have a friend that wants to start using it like I do!
TIA
David
If you mean the MapSource link there is both a link to the patch and MapSource itself, you've clicked on the wrong one. The main download button is 57Mb which is the main program, the patch is only a few Mb
