Hi from UK
Grumly
Hi from UK
Post by Grumly »
Hi There. Seem to have ended up with 4 garmin's and basecamp and still struggle at times on long days motorcycle rides/tours. Hoping to gain some guidance on the issue of planning a route with just a few waypoints ( and ending up in a farmyard yet again ) or loads and then trying to work out how many confusingly named waypoints to skip when I come across a shut road blocking off access to a whole section of the route.
Been liked: 265 times
Re: Hi from UK
Hi and welcome to the forum
There is plenty of information on using basecamp and route planning
Try some of the videos that @jfheath has done viewtopic.php?t=2057
Re: Hi from UK
Hi. Welcome.
What model zumos do you have ?
Believe it or not, they behave differently from each other so it helps to know.
Re: Hi from UK
jfheath wrote: Sat Jan 14, 2023 10:55 pm Hi. Welcome.
My question and reasoning exactly! Expecting them to all act the same got me in loads of trouble.
Grumly
Re: Hi from UK
Post by Grumly »
Cheers. Yes I thought they would behave the same, was so surprised when they look/feel so different. You would have thought they would add features and improve performance instead of re writing the whole interface. Anyway ancient zumo 220 ( still going strong ), zumo 346 ( causing the issues touring and long days out ), wife has a drive smart 51 lmt-s and another there is an old E1000 which I never got on with for more than one trip.
Re: Hi from UK
I've not owned any of those. I still have my original Magellan 4000 though. I'll have to write a spoof account on that one !
I think the closest to what many of us use would be the 346. Was your previous one a 346 Russ ? (@rbentnail ).
Re: Hi from UK
jfheath wrote: Sun Jan 15, 2023 9:18 pm I've not owned any of those. I still have my original Magellan 4000 though. I'll have to write a spoof account on that one !
Going backwards in time I have the XT for the bikes, the 595 I moved to my truck and before that for many yrs I used a nuvi780. The nuvi, besides not being weather resistant, was by far the easiest and most intuitive of them all with the most helpful features for me. It will still boot up and communicate with Express but its functionality is long gone. I got it factory refurbished for a ridiculously low price to learn with and it took me the length of the eastern USA more than once, at least 100,000 miles traveled with that thing before it started dying.
Miarose
Re: Hi from UK
Post by Miarose »
Hi
