I have mostly been transferring routes from BC to my XT using the SD card mounted on my Mac. But several times laziness (it's a pain to get at the back of my iMac to plug in the SD card) has prompted me to use email and Garmin Drive. It has worked fine for trips I'm not interested in storing on the SD card. Until this morning.
The route imported OK according to the XT, but never showed up in Trip Planner saved routes. I tried again, same result. I power cycled the XT and now have two instances of the route in Trip Planner.
Your thoughts?
Garmin Drive odd behavior
- Has liked: 148 times
- Been liked: 139 times
Re: Garmin Drive odd behavior
Frank, I followed good advice here to never allow Explore onto my system, so yes, this was Drive and I agree it's odd.
I just tested it and the transferred route was in Trip Planner > Saved Trips. Hopefully your experience was just an anomaly in Trip Planner not updating its list. The reboot cleared it up.danham wrote: Wed Apr 12, 2023 11:26 am The route imported OK according to the XT, but never showed up in Trip Planner saved routes. I tried again, same result. I power cycled the XT and now have two instances of the route in Trip Planner.
Your thoughts?
