BMW Navigators
Need help with the forum? or got some forum feedback? Please use this section.
Bob
BMW Navigators
Post by Bob »
Hi Stu,
Would it be possible to have a separate section for the BMW range of Navigators, e.g. the Nav IV, Nav V, and Nav VI?
I know they are similar to the Garmin models they are based on but, on the later models, they are getting features that are more unique to BMW.
Cheers
Bob
Been liked: 265 times
Re: BMW Navigators
Yes no problem I will get that sorted later for you
Is that the full list of available bmw navigators above?
Bob
Re: BMW Navigators
Post by Bob »
No, they did do an equivalent to the 550, but I think it was pretty much identical to the Garmin 550, there my be earlier models, I'm not sure.
Cheers
Bob
