No!
In this video create a new route.
I have the google maps extension. How do I import the example link into google maps?
Link Googlemaps to GPX
Re: Link Googlemaps to GPX
That route looks like it would be very easy to duplicate in BaseCamp. Use Alt-tab to toggle between a Google Maps window and a BaseCamp window as you create it in BaseCamp. In case you are not aware, you can right click on any point on the route in the Google Map and copy its coordinates which you can then paste into a BaseCamp waypoint.Raf wrote: Thu May 11, 2023 3:01 pm Okay!
But I don't have to create. I have links already created , not from me, and I need to convert.
