Where are tracks stored?
For everything Garmin Zumo 345/350 related
Bear
Been liked: 3 times
Post by Bear »
My Zumo 350 has CN2024.1 split between internal storage and a 32GB SD card. When I ask BaseCamp to read from the Zumo it gives me the choice of main memory or SD card but, since I fitted the card, no history comes out of it. Where is travel history stored: main memory or SD card and how can I diagnose the absence of it. It is turned on wherever it appears in settings.
Has liked: 365 times
Been liked: 376 times
Re: Where are tracks stored?
History is stored in internal memory, it shows as a track or tracks so ensure you're looking in the right place in BaseCamp
Bear
Been liked: 3 times
Post by Bear »
Thanks for the info. Next time I use the 350 I'll see what I get back from it.
Has liked: 404 times
Been liked: 889 times
Typically, internal storage in the GPX folder.
Tracklog.gpx or CurrentTrackLog.gpx
However, it will not be recorded unless you have specifically asked it to when you first got your Zumo.
I don't know the menu of the 345/350 - but look in Settings, Device, Travel History.
Mine says 'myTrends, Tracks, Where I have been' Whatever yours says, it needs to be ticked.
