XT2 fits in XT Touratech lockable mount?
Chopperbob
Has liked: 21 times
Post by Chopperbob »
Anybody know if this fits?
The XT2 is only 8mm wider...
Thanks
Robert
Been liked: 265 times
Re: XT2 fits in XT Touratech lockable mount?
I have seen a post somewhere in that you can take the rubber pads out and shave them down a touch to make it fit
Chopperbob
Has liked: 21 times
Touratech claims is doesn't fit, but I would expect them to say this too,...
Will have a look at my mount to see it that is possible
RJ
Well they would say that so they can sell you a new one!
