The time displayed on 660
DT1832
Post by DT1832 »
Recently dure a all day ride twice I noticed the time displayed was not keeping good time as the ride went on. Twice when I turned on the 660 the time was correct but like 1 1/2 hours into the ride the time was off by 1/2 hour which also effected arrival time. What's going on with it, is this GPS starting to fail?
Has liked: 369 times
Been liked: 787 times
Re: The time displayed on 660
Sorry - late reply. Welcome to the forum.
The time being wrong is unusual. It should be getting a time signal from the satellites. If it doesn't have an accurate time, then it cannit locate your position accurately.
Which time display are you referring to - one on the map view ? Are you sure it is the time of day that it is displaying and not (say) arrival time ? Can you post a screen shot ?
