Insufficient power
garmerlend
Norway
Insufficient power
Post by garmerlend »
I have a usb outlet on my bike, and i tried to use this outlet as a power source to my zumo xt, using the mini-usb cord(mini-usb to normal usb(usb-a) cord).
The battery on the zumo was fully charged when my trip started. After 3 hours the zumo had low battery. It seems the mini-usb cord isn't powerful enough to keep the xt charged. Is this normal?
Can i get another mini-usb to usb-a that gives mor power(amps)?
I'm a neewbie when it comes to power and amps etc...🙂
Has liked: 117 times
Been liked: 348 times
Re: Insufficient power
You need a 2 amp power which the usb port on your bike likely doesn't provide. If it does then a power-only cable could be a solution. The cable provided by Garmin, and generic replicas, provide both power and data. Even though there is no data, the cable tricks the XT into thinking that there is which throttles charging. I think you will find that wiring directly to the battery or an alternate power source on the bike is the way to go. The XT will draw power when connected so a switched power source will eliminate battery draw when the bike is parked. Otherwise you will need to be conscious of disconnecting the XT when you park the bike.
This cable works for me in my car which has a 2 amp usb. My bike does not so my XT is wired to an auxiliary power source.
https://www.amazon.com/gp/product/B096ZC2VFH
Has liked: 414 times
Been liked: 229 times
It's not a good idea to provide power like this as the vibrations can destroy the usb port on the XT
Has liked: 104 times
Been liked: 221 times
Stu wrote: Mon Jul 24, 2023 9:37 pm It's not a good idea to provide power like this as the vibrations can destroy the usb port on the XT
I thought the same thing.
BashStreetKid
Has liked: 25 times
Post by BashStreetKid »
garmerlend wrote: Mon Jul 24, 2023 8:00 pm I have a usb outlet on my bike, and i tried to use this outlet as a power source to my zumo xt, using the mini-usb cord(mini-usb to normal usb(usb-a) cord).
I'm curious why you simply don't use the cradle which the device came with?
