I've searched through the menus to see if the is an option to turn it on, but I cannot find one.
I would love some help with this please.
Thanks a lot
All sorted, things are back to normal as they should be. Thanks for your help everyone.Backup saved addresses/routes with Garmin Express, complete a master reset, let unit acquire satellites then reinstall the map.
Backing up, Restoring, or Transferring Saved Data on Garmin Automotive Devices: https://support.garmin.com/en-US/?faq=G ... ery=backup
Touch View Map
Touch the Speed icon
Touch and hold the speedometer for approximately 5 seconds
Release your touch when the Diagnostics Page displays
Touch Clear all user data
Touch Yes when prompted to "Erase all user data?"
The device will now be reset. Follow the on-screen prompts, then place the device in an area with a clear view of the sky until it acquires satellites outside up to 5 minutes.
Reinstall or Change Map on an Automotive Device: https://support.garmin.com/en-US/?faq=d ... install%20
