Zumo XT was working fine for months and suddenly the map street detail is gone. It only shows major roads now. Just blank when I zoom in. It's very strange. Also it won't calculate any routes...just says can't calculate route every time. I have reset the darn thing and added a 256gb SD card and still no change. Any ideas before I send it back to Garmin?
Thanks
Zumo XT map detail gone and can't calculate route
- Has liked: 117 times
- Been liked: 348 times
Re: Zumo XT map detail gone and can't calculate route
The only thing I can think of to check is the enabled maps. Go to Settings > Map & Vehicle > myMaps and make sure the CN North America NT map is ticked. Also, I have read on this forum about problems resulting from multiple navigable maps being enable. I don't know how those problems present themselves so in the event the you have other navigable maps, these are the maps I have enabled:
National Parks v2
TopoActive PS NA, US
North America DEM
CN North America NT All US
CN North America NT Parkopedia
I don't have CN North America NT Foursquare enabled by choice but I know that it is ok to enable with the ones listed above.
As far as I know, only the CN North America NT All US is used in calculating routes.
Also in Map & Vehicle are options for setting map detail and map layers although I don't think anything in those options would cause what you describe.
National Parks v2
North America DEM
- Has liked: 104 times
- Been liked: 221 times
This is what I had to do also. Give it a try.
