Hello,
I've bought a XT2 and I'm experiencing some problems. The biggest, for me, is that after a re-calculation of the route (because I've deviated from the route) the pink line with the new route dissapear. Indications on the top are correct (Icon and text). Also the instructions by voice, but the graphic pink line on the map dissapear.
I have software version 4.4 and maps updated.
Any idea? Anyone of you with the same problem?
Thanks to all,
Pink line dissapear after re-calculate (Garmin XT2 - Solved)
Re: Pink line dissapear after re-calculate (Garmin XT2)
Yes, I knew the workaround.
More info about it:
* Another work around much faster is swipe the finger to enter the edit route screen, touch the "show all route" icon and come back to the navigation screen. When you have a route with more than 1 stop is much better this option
* The problem only appears when you load a route and there are shapping points or Waypoints before destination. If destination is the last stop in the route or you drive directly to a destination, without a route, the problem doesn't appear
Is very very uncomfortable to navigate in this conditions.
More info about it:
Finally, with the recent v4.5 the problem has been solved
