396 Battery Level Check
- twowheelstom
- Has liked: 146 times
- Been liked: 54 times
being new to the 396 Zumo, the 550 has a battery level icon that shows battery charge level, but where on the 396 can the battery level be checked? I put the 396 on a wall charger but I don't see where I can check the battery charge level on the 396.
Zumo 396
1994 Yamaha 250
1994 Yamaha 250
MSTOCK27370
- Has liked: 22 times
- Been liked: 44 times
Re: 396 Battery Level Check
When it's turned on, and not in the cradle, the battery icon in the upper right will show a charge status/level. When it's in the cradle, it will show that it is charging, as long as the cradle has power.
Michael S.
Trinity, North Carolina
- twowheelstom
found the icon when turned on like you said, it was at half charge, now i feel dumb, lol you are helping me thanks, guaranteed i will post more dumb questions in the future lolMSTOCK27370 wrote: Wed Jan 03, 2024 8:15 pm When it's turned on, and not in the cradle, the battery icon in the upper right will show a charge status/level.
Zumo 396
1994 Yamaha 250
1994 Yamaha 250
- Has liked: 183 times
- Been liked: 166 times
If you press the battery icon, for about 10 seconds, then it'll show the state of the battery, charging current etc etctwowheelstom wrote: Wed Jan 03, 2024 8:50 pmfound the icon when turned on like you said, it was at half charge, now i feel dumb, lol you are helping me thanks, guaranteed i will post more dumb questions in the future lolMSTOCK27370 wrote: Wed Jan 03, 2024 8:15 pm When it's turned on, and not in the cradle, the battery icon in the upper right will show a charge status/level.![]()
