No Maps on the Basecamp - Urgent help
Raf
Has liked: 16 times
Been liked: 5 times
Italy
Re: No Maps on the Basecamp - Urgent help
Post by Raf »
All clear. But now how can I get the NT versions back on Basecamp?
There is a way?
Raf
Has liked: 16 times
Been liked: 5 times
Italy
Post by Raf »
Cannot uninstall. This is the warning.
Allert
Allert
You have a corrupted Windows uninstaller. If you search on Google you'll find ways to repair it. Once you've repaired it you should be able to uninstall the maps and then use Express to reinstall them.
Raf
Has liked: 16 times
Been liked: 5 times
Italy
Post by Raf »
The problem is only for that. I uninstalled the other versions. Now I have only the latest ntu version, 2025.10.I can't find the NT.
I'd still repair your uninstaller. You could also try JaVaWa's GMTK to remove the maps
https://www.javawa.nl/gmtk_en.html
Raf
Has liked: 16 times
Been liked: 5 times
Italy
Post by Raf »
It's invasive Like Geek?
Nope
