sussamb wrote: ↑Wed Oct 17, 2018 8:20 am
You can use TE versions with BaseCamp, but only with the device plugged in. The other alternative is to copy the maps to a SD card or memory stick and use that instead. Map files need to be placed in a folder named Garmin on the card/stick.
Perhaps a stupid question from someone who has had a number of years experience with Garmin.
But how do you actually copy the map-set (and make it work) to a USB drive?
Edit: I would like to plan for a trip to the States, as well as having a similar Europe map available.
Thanks
Sleuth
Maps: Europe NTU 2024.10
Halo.
I have a TE and try to copy the map so I can worke in BC without having my Z595 on. But I can´t find the map file. I have put my 595 into MSS mode and there are no file .img. I have the box "hiden objekts" checkt. I have tryed every singel map and can´t find the map file. I hate this TE. I did not knew there were that kind of edition when I bougt it.
Hope for help
The total folder (F) Garmin zumo sise are 5,04 GB out of 9,24. The sise of the "Map-folder are just 15,3 kB!!!! The unit must hide the .img-fil somwere.
Halo sussamb
Many thanks for your quick respons. I have found the .System. My goal is to copy the maps to a stick in order to use it when I "works" i BC. Do you knew if it´s just the "gmapprom.img" I copy to a "Garmin-folder" on the stick?
The latest Europe-map is now so big that they have divide it in to four or five regions. Is it possible to have two or tree "gmapprom.img in the same Garmin-folder. If "yes" - maybe I should give them different names - eg "gmapprom1.img"?
Is it even possible to have more than one "gmapprom.img" in the .system-folder in my ZumoTE?
Not sure how it works on your device but other maps are normally in a Folder named Map. I'm not sure either how the Travel Edition handles additional maps but if you search your device for .img files it should be obvious which are the map files
