I noticed that after the latest update, the "SHOW ON MAP" option for tracks is no longer available.
Am I doing something wrong?
Thank you
Show on MAP tracks
Re: Show on MAP tracks
It is still showing on mine. Software version 6.60. No update recently. Garmin Express says it is up do date.
Apps > Tracks > Select a track > Spanner > Scroll down
- Has liked: 87 times
- Been liked: 248 times
Show on map does not appear if you have Explore enabled - you'll have to include the track as part of the current Collection (or whatever they call it).
Many of us prefer to disable Explore by first uninstalling the app from our phones and then resetting the XT to factory settings, skipping the Explore activation during the initial setup.
EDIT: there are much better instructions from @jfheath here.
I reset the XT and skipped Explore sinchronizationlkraus wrote: Mon Jul 08, 2024 9:01 pm Show on map does not appear if you have Explore enabled - you'll have to include the track as part of the current Collection (or whatever they call it).
Now it work properly
Thank you
