Earlier versions of maps
Is it possible to revert to earlier maps the latest update has proved a disaster for one of my units
- Has liked: 1 time
- Been liked: 32 times
Re: Earlier versions of maps
Not to cross post between your threads, but each Garmin device has to have it's own independent, specific unlock code for each map version you try to put on it. Just because you may have an older map version unlocked for (1) 660 does not mean you can install the same map on a 2nd 660 without it's own unlock code.
