Lack of data
Palfers
Lack of data
Post by Palfers »
I have a zumo 660. Few years old now. I’ve just updated the maps but now when I try to enter a new destination address I get a notice ‘ No Data Available’. I have a 16 go card fitted. Do I need to get a bigger sd card?? Thanks all.
kernowing
Has liked: 131 times
Been liked: 58 times
Re: Lack of data
Post by kernowing »
Welcome to Zumo User forum Palfers.
Like yourself, I have an aged 660 LM on which I have only recently updated the maps to 2025-10. The update shows 5.1GB which is too big for the Z660 internal storage. I used MapInstall to update the maps to my SD card (32GB) but your 16 GB SD card should be plenty big enough.
2007 GL1800 Goldwing
Zumo 660LM
Palfers
Re: Lack of data
Post by Palfers »
Hi thanks for your reply. I’m a bit puzzled then as to what to do next? It worked fine before I updated. Did it through the Garmin site so assume it’s authentic?
kernowing
Re: Lack of data
Post by kernowing »
Palfers wrote: Wed Aug 21, 2024 7:56 am Hi thanks for your reply. I’m a bit puzzled then as to what to do next? It worked fine before I updated. Did it through the Garmin site so assume it’s authentic?
May be a silly question but do you have Garmin Express and Mapinstall on your PC/laptop?
Zumo 660LM
Palfers
Re: Lack of data
Post by Palfers »
To be honest I can’t remember which route I took but I will check later👍
