Newbie question re: USB power
Bluto
Post by Bluto »
Forgive this newbie question but Is there a way to power the 550 via USB connector so that it boots up in GPSr mode (as opposed to 'connecting to PC' mode)?
electro_handyman
Been liked: 37 times
Re: Newbie question re: USB power
Post by electro_handyman »
If you have the correct type of USB cable the unit should initiate startup into USB mode.
The unit will not "run" on USB power alone if that's what you are asking.
Has liked: 148 times
Been liked: 455 times
I don't know what GPSr mode is but with the XT, if I connect it to the USB port in my car using a cable that is capable of data and charging then it will boot into "connecting to PC". It will not do this with a charging-only cable. This is the one I use in my car. https://www.amazon.com/gp/product/B096ZC2VFH
Has liked: 73 times
Been liked: 193 times
Some car radios can play music stored on a USB stick or phone, that is, they can transfer the files. These will look like a computer to the XT because they are trying to establish a data connection. If the car has more than one USB socket, try a different one, Otherwise, use a charge-only cable with this type of USB port, or use a USB adapter in the cigarette lighter socket.
Bluto
Post by Bluto »
electro_handyman wrote: Wed Aug 21, 2024 10:00 am The unit will not "run" on USB power alone if that's what you are asking.
Yes, that is what I was asking. Thanks.
Bluto
Post by Bluto »
Peobody wrote: Wed Aug 21, 2024 12:45 pm I don't know what GPSr mode is
i.e. GPSr mode vs 'attached mass storage' mode.
