Won't connect to computer
Franck
Re: Won't connect to computer
Post by Franck »
Hello all,
I have the exact same trouble.
I can connect my previous GPS 395 with the same USB Cable, same port, everything works fine.
But with my 396, can't see the USB storage anymore.
I factory reseted the 396, same issue.
I tried the MASS storage solution as per @jfheath , same issue
I hold the switch button for 1 min, same issue (when ON, and also when OFF)
I turn it on holding the bottom right corner to do a reset, same issue
I tried with a different USB cable and different port on my laptop, same issue.
I (of course) rebooted my laptop
I turn it OFF and ON several times the GPS, same issue
So, I am running out of solution.
Everything was fine until this morning, I deleted all my favorites, and tried to connect as usual (a couple of minutes before, actually) to do a restore backup, but the GPS internal memory do not shows up on PC, and the GPS 396 not showing on Garmin Express.
Garmin Express runs in the background, even when you have closed it down. Stop it from doing thar, and from loading at startup, using the options in the gear icon.
Also - try task manager CtrlAltDel. Kill any programs that you think may be trying to use the USB port.
Franck
Post by Franck »
Thanks but it's not that.
I know for years to stop and not start at boot Garmin Express.
I have no other program using the USB port.
As I wrote, I tried with a different laptop (no Garmin softwares installed) and same thing, can't see in file explorer the GPS.
Since the 395 connects properly using the same cable, PC, and software, I suspect the data pins of the 396 USB port are not making good contact with the cable.
You might try inspecting the port for dust or dirt.
It may also be worth trying different cables. Every USB-C cable I own works with my phone, except one charging cable that does work with my wife's identical phone and other devices.
If you still cannot connect to your PC, it might be time to have the 396 port replaced. PalmDr is often recommended here in the U.S., but you may be able to find a closer repair shop.
Franck
Post by Franck »
Thanks guys for your replies.
I contacted Garmin support, my GPS is 20 days old!
As I mentioned, this is NOT related to laptop nor cable, since:
- I tried with a different laptop, same issue
- I tried with different USB cables, same issue
- I CAN connect my previous Zumo 395 with same laptop, same USB port, same cable, without issue.
- Cleaned with contact cleaner USB cables, both ends, and mini USB port at the back of GPS
We tried factory reset with Garmin support, change storage, connect and keep power button pressed for 30 sec, remove SD card (connect without SD card). They can`t figure what is wrong.
This is not a question to "how to import my favorite" but why the almost brand new GPS can't log on my laptop, as I have done many times before.
Franck wrote: Mon Sep 23, 2024 1:07 pm I contacted Garmin support, my GPS is 20 days old!
You have a one year warranty. Invoke it and get a replacement.
Franck
Post by Franck »
This is what I'm doing now. But I have a motorcycle road trip in Baja California, starting this Friday, and need a GOS before this date. I was hoping to fix it before.
lakson
Slovenia
Post by lakson »
Hi, I know this is kind of a old topic but I have a very similar problem.
I bought a second hand Garmin Zumo 595LM. At first everything seemed fine. When I got it, I downloaded the latest updates, maps and everything and then the downfall started...
About a month since I got it I went on a trip to test it out when I realized that one of the local highways that was construced a few days ago was not on drawn in the maps. So I went to Garmin Express to update the maps and I got greeted with "USB device not recognized". I tried everything, went through 5 cables, two laptops and multiple factory and windows resets... nothing...
One more thing that I noticed is that the unit behaves the same when it is on charger and connected to a PC. It shows the media transfer icon for about 20 sec and then it goes into normal operation mode (Again it behaves the same when connected to a PC and a charger)...
Does anyone have a solution to this problem
Welcome to the forums.
I just blew the dust from my 595 so that I could answer you - but then read through all of the earlier posts.
Everything that I could suggest has already been suggested. Some of it by me, some by others. Have a read through.
But I would start by trying different cables. If buying new make sure that they are for power and data / synch. It is common for the tiny internal wire cores to break inside - especially near the plugs where the wires get bent through 180 degrees - so just 'cos a cable worked a month ago, doesn't meant that it will work today.
lakson
Slovenia
Post by lakson »
Sorry for no formal introduction, quite rude on my side...
I tried every technique suggested, went through 4 cables, two laptops, after your reply I even opened up the device and checked the pins on the connectors but every thing seemed snug and fine. Since Garmin support is out of the question due to age, I'll send it to a private company to service it and I'll report back (They are at peak of season now, so they won't be able to repair it till start of October).
If anyone has any advice until then, I'll be happy to hear it!
