Tread 2.08.37 quirks
Is it me, that if you create a route in Tread, and use stops and then later convert them to shaping points, that the app can change the route taken, as well as the known problem of moving what was the via to a shaping point. And it depends on what order you change them over to what might happen as well.
This seems to be consistent behavior, but I am 99.9999% certain that the changes that occur might change if you do use the undo option, and then redo the changes? This then makes it difficult to work out what is happening as the behavior can't be replicated!
Or is it just me?
turbo19
Has liked: 193 times
Been liked: 47 times
Andorra
Re: Tread 2.08.37 quirks
Post by turbo19 »
Not just you. We've been using this version for 2 and a half months without Garmin updating it. It's a disgrace. I'm happy with having a stable Bluetooth connection between my phone/XT2 (not even that yet).
It's pathetic.
