Solved ? : Connectivity problems with Garmin Zumo XT2
Re: Solved ? : Connectivity problems with Garmin Zumo XT2
Yes.
Until I started experimenting with Tread, everything worked fine. Basecamp routes imported and behaved. Phone worked every time.
RUT symptoms were improved (but not cured).
The only issues were
Tendency to head for faster roads, rather than fastest. But not so different from XT
Rut behaviour still exists, but solved by using the Copy facility. The copied route is identical but set as saved, rather than imported.
turbo19
Has liked: 193 times
Been liked: 47 times
Andorra
Post by turbo19 »
I have removed the video. ;)
I'm not sure what is not happening.
The phone rings and then ...... ?
I notice the phone keeps cutting off.
I have noticed different behaviour with my phone when connected by BT.
When connected by BT, it behaves differently when the phone is on (as if I was using it ) when the call is made
from when it is 'off' screen blank - as if it was in my pocket.
But I have yet to fiddle with the settings to see what this behaviour actually is, and whether the settings change it.
turbo19
Andorra
Post by turbo19 »
jfheath wrote: Fri Dec 06, 2024 6:08 pm I'm not sure what is not happening.
The bluetooth from XT2 disconnects when Tread App syncs. I just touch the screen to show that the bluetooth disconnects from both the phone and the intercom. There are also interruptions with syncs, and the XT2 asks you to reconnect to the Tread App. It seems that bluetooth saturates when there is a call if Explore sync is active in Tread App.
turbo19
Andorra
Post by turbo19 »
The only way I have found to synchronize external things (in my case almost all tracks and wp) is by inserting them through the XT2's internal memory (either in the GPX folder of the internal memory or in the MicroSD). This way, once synchronized with the Tread App, Bluetooth interruptions do not occur.
My XT2 seemed to be unstable, so I carried out a hard reset on it. And now Tread and it seem to be unhappy.
Previously when I turned on my XT2 it would connect to Tread automatically, no more :( But after half a dozen or so starts it is now connecting automatically.
I have Tread on a Samsung tablet, which was working with the XT2 nicley, now the XT2 will not connect to it, apart from music :(
Tried deleting Tread off the tablet, no change.
FFS :evil: :evil:
Edit #1
Deleted Tread again off the tablet, forgot it on the XT2, reinstalled Tread and then used the tablets camera on the XT2 QR code, and it's now connected 😀
