Music services for XT
twowheelstom
Has liked: 100 times
Been liked: 40 times
Post by twowheelstom »
Is there a music streaming service for my XT to play music on motorcycle trips?
MotoToph
Has liked: 28 times
Been liked: 15 times
Re: Music services for XT
Post by MotoToph »
Yes. Any of them.
You will need a cell phone to stream to the XT. The XT will display the album art and you can pause, play, and skip from the XT if you wish.
ZUMO XT
K1600GT
Mzokk
Has liked: 32 times
Been liked: 21 times
Post by Mzokk »
For streamed stuff I use spotify and if I'm out of mobile coverage I have about 20gb of music on my phone that I play through Musicolet. Both work well with the XT.
Has liked: 109 times
Been liked: 252 times
Good luck getting the XT to reliably play music from your phone. The Bluetooth connectivity requires constant fiddling, and on average about every third time I tried it it wouldn't work at at unless I completely unpaired EVERY device from the XT, then paired them IN THE SPECIFIC ORDER needed, and even then it broke up the audio regularly until it quit completely AGAIN. Do yourself a favor- put about 6000 songs on an SD card, put it in the XT and play music from there. You'll end fewer days with heartburn and headaches from the aggravation.
Mzokk
Has liked: 32 times
Post by Mzokk »
Mine phone seems to work fine with the XT, obviously not the same for everyone!. I have music on the SD card but the music navigation and playlist play of spotify and musicolet is much better than playing music direct from the unit.
Has liked: 140 times
Been liked: 435 times
Music from my iPhone was unreliable, but worse, it automatically started playing as soon as the phone was connected. I put the music on the SD card and disabled it on the XT by turning off the "Media Audio" option in the bluetooth connection configuration for the phone on the XT.
