Any exposed electrical contact setup will require some user maintenance. That's just a fact of life. Unless you're willing to pay an astronomical cost, the maker cannot be expected to accommodate every world-wide condition that may be seen by its equipment. IMHO the owner bears some of the responsibility for keeping things in good working order.finerone wrote: ↑Mon Jan 13, 2025 7:47 pm It's interesting how a simple mechanical adjustment can fix what seemed like an electrical issue. Garmin should probably take note of this common problem with their mounting system. Cheers for sharing the fix - might help others with the same Zumo XT charging headache.
cradle mount charging problem
- Has liked: 110 times
- Been liked: 254 times
Re: cradle mount charging problem
- Has liked: 432 times
- Been liked: 952 times
What you describe is what happens when the battery is not fully charged - and it will do this even when connected to a house charger - because the XT takes more power than the charger can typically provide.
If using a house charger, the XT needs to be in standby mode and left to charge for 24 hours.
Or if in the bike cradle it requires a number of good long runs.
You can check what current / voltage is being used/supplied - long press the battery charge icon.
The USB connector is a known weak point.
